SBC to LS |
SBC to LS |
dwillouby |
Oct 21 2019, 02:44 PM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello,
Recently realized that I haven't been pouring enough money into my 914. Currently have a iron 355 SBC mated to a 04 Boxster s 6 speed. Had the trans in for about a year now and should had went with the LS back then. So now trying to figure what parts I need to collect and what I can sell. Trying to stay away from Renegade's overpriced parts. Hopefully some of you guys can chime in. Will get the adapter kit & clutch from Kennedy. Cooling log from Toy-Jet. Believe I can use my motor mount bar if I use the LS-SBC adapter plates. Will need to use a different electric water pump. Still working to locate a good engine choice. As the LS1, LS2, & LS3 motors are so hard to find affordably I am looking at an LQ4 or LQ6 to build as they are more reasonably priced. May decide to use my current Fast efi throttle body along with the MSD controller. Just hate to remove good working systems but may toss anyway. Any thoughts suggestions will be appreciated. Thanks David |
dan10101 |
Oct 21 2019, 04:40 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Personally, I would look for a L76. Alum block 6.0 makes lots of hp found in trucks.
I'm sure there are others that are alum block, but this one I know about. https://www.onallcylinders.com/2018/05/10/l...ze-performance/ You are 1/2 way there with the Boxster S 6 speed. |
sb914 |
Oct 21 2019, 04:57 PM
Surf Guru Group: Members Posts: 4,315 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Hello, Recently realized that I haven't been pouring enough money into my 914. Currently have a iron 355 SBC mated to a 04 Boxster s 6 speed. Had the trans in for about a year now and should had went with the LS back then. So now trying to figure what parts I need to collect and what I can sell. Trying to stay away from Renegade's overpriced parts. Hopefully some of you guys can chime in. Will get the adapter kit & clutch from Kennedy. Cooling log from Toy-Jet. Believe I can use my motor mount bar if I use the LS-SBC adapter plates. Will need to use a different electric water pump. Still working to locate a good engine choice. As the LS1, LS2, & LS3 motors are so hard to find affordably I am looking at an LQ4 or LQ6 to build as they are more reasonably priced. May decide to use my current Fast efi throttle body along with the MSD controller. Just hate to remove good working systems but may toss anyway. Any thoughts suggestions will be appreciated. Thanks David Interested in adapter (IMG:style_emoticons/default/idea.gif) |
dwillouby |
Oct 22 2019, 09:28 AM
Personally, I would look for a L76. Alum block 6.0 makes lots of hp found in trucks. I'm sure there are others that are alum block, but this one I know about. https://www.onallcylinders.com/2018/05/10/l...ze-performance/ You are 1/2 way there with the Boxster S 6 speed. Thanks Dan, Didn't consider the L76 due to the VVT but now looks interesting. BTW been following your build, great car!! David |
dwillouby |
Oct 22 2019, 09:30 AM
Hello, Recently realized that I haven't been pouring enough money into my 914. Currently have a iron 355 SBC mated to a 04 Boxster s 6 speed. Had the trans in for about a year now and should had went with the LS back then. So now trying to figure what parts I need to collect and what I can sell. Trying to stay away from Renegade's overpriced parts. Hopefully some of you guys can chime in. Will get the adapter kit & clutch from Kennedy. Cooling log from Toy-Jet. Believe I can use my motor mount bar if I use the LS-SBC adapter plates. Will need to use a different electric water pump. Still working to locate a good engine choice. As the LS1, LS2, & LS3 motors are so hard to find affordably I am looking at an LQ4 or LQ6 to build as they are more reasonably priced. May decide to use my current Fast efi throttle body along with the MSD controller. Just hate to remove good working systems but may toss anyway. Any thoughts suggestions will be appreciated. Thanks David Interested in adapter (IMG:style_emoticons/default/idea.gif) Hi will most likely remove it this winter. Will PM you when I do. David |
dan10101 |
Oct 22 2019, 07:22 PM
Personally, I would look for a L76. Alum block 6.0 makes lots of hp found in trucks. I'm sure there are others that are alum block, but this one I know about. https://www.onallcylinders.com/2018/05/10/l...ze-performance/ You are 1/2 way there with the Boxster S 6 speed. Thanks Dan, Didn't consider the L76 due to the VVT but now looks interesting. BTW been following your build, great car!! David VVT can be disabled or manipulated. You will need to disable VATS anyway if you're using a stock computer. This guy has a real good handle on the process. This is using HPTuners. https://www.youtube.com/watch?v=NtBPWIXCBQA I'll be following to see how the connection LS to BoxsterS goes. I finally have my 4 speed working well, but it's a pretty wide gap. |
theer |
Oct 22 2019, 07:53 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
The L33 5.3 liter is also aluminum block... found in quad cab chevy/gmc pickups. It's not the classic 350, but has more than enough HP and has a higher red line. Could be fun!
dan10101 |
Oct 22 2019, 08:59 PM
The L33 5.3 liter is also aluminum block... found in quad cab chevy/gmc pickups. It's not the classic 350, but has more than enough HP and has a higher red line. Could be fun! Yeah, a 5.3 would be plenty even in stock trim. Plus it takes mods really well. https://www.onallcylinders.com/2018/04/26/l...ze-performance/ |
djway |
Oct 22 2019, 09:30 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I found an aluminum 5.3 ls1 out of a 4wd Trailblazer and also got an LS6 intake and LS1 oil pan plus some high flow injectors from the same guy. I am also switching to drive by wire TB. Sent all the specs with the proper brain and had it reprogrammed.
Really wish I could swing the dollars for the Boxster trans. |
FL000 |
Oct 22 2019, 10:36 PM
Member Group: Members Posts: 397 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
David,
Just curious on your main reasons to swap since I am in a similar boat. Less weight, more power, higher RPM, other? Josh |
VaccaRabite |
Oct 23 2019, 05:59 AM
En Garde! Group: Admin Posts: 13,463 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
dwillouby |
Oct 23 2019, 03:23 PM
David, Just curious on your main reasons to swap since I am in a similar boat. Less weight, more power, higher RPM, other? Josh The motor I have now is all iron 425hp 350 Chevy. Fast EFI, Big cam ect. Runs good but just want a more modern engine. An LS2 is a lot less weight with modern FI ect. I guess I really just want a change? David |
Gearup |
Oct 24 2019, 06:34 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Hey there! I just got a Boxster 6 speed in great shape and no issues for $750 last week. 2 days ago I got a rebuilt LS1 with ECM, beautiful looking wiring harness and pedal harness and drive by wire assembly for $3200. If you keep watch some good deals pop up. Got it on Craigslist and ironically it was 5 miles from my mechanic so we go to check it out. I called Kennedy about their package and if you are going to get the LS kit from Renegade it appears that renegades Boxster kit had more and for less money when you buy the two. I will be curious to see what you source for your project. It is big money for those kits for sure. |
Front yard mechanic |
Oct 24 2019, 06:52 PM
Senior Member Group: Members Posts: 1,170 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Pictures I want to see pictures (IMG:style_emoticons/default/hissyfit.gif)
BIGKAT_83 |
Oct 25 2019, 01:32 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
David
These Guys make a nice adapter set up. The flywheel is aluminum with a removable steel face. A little less $$$ than the kennedy setup. |
djway |
Oct 25 2019, 09:25 PM
David These Guys make a nice adapter set up. The flywheel is aluminum with a removable steel face. A little less $$$ than the kennedy setup. Your killing me Bob |
dwillouby |
Oct 26 2019, 12:09 PM
Thanks Bob,
Flywheel looks nice. Something to think about. David |
dakotaewing |
Oct 27 2019, 05:19 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
@Bigkat_83 Any suggestions for clutches that don't run $700?
BIGKAT_83 |
Oct 27 2019, 11:24 PM
You can get a stock Boxster S part# 134-05438261 clutch, pressure plate and throw out bearing from parts geek for $250. I'll bet this would work ok with a mild LS |
partwerks |
Oct 28 2019, 05:49 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Which Boxster S trans is the one that had that pop out in 2nd gear?
Lo-Fi Version | Time is now: 4th June 2024 - 09:46 AM |
