Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
rhodyguy |
Oct 22 2019, 04:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If not done do Andy's ground wire between the relay board and chassis mod. The board relay And fuse need to be place. If only to get it running. the pump will be activated continuously but stop running after the pressure builds. 3 full pumps and a bit of throttle feathering it should come to life. Did you get the CB Weber book when you bought the pump?
Lo-Fi Version | Time is now: 18th May 2024 - 02:20 AM |
