Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
surfdogskier |
Oct 22 2019, 03:11 PM
I did not change the setup with the wires to the existing fuel pump. I used the same ones I had in my high pressure pump from the fuel injection.
I just don't hear this fuel pump like I did my other fuel pump. |
bbrock |
Oct 22 2019, 04:16 PM
I did not change the setup with the wires to the existing fuel pump. I used the same ones I had in my high pressure pump from the fuel injection. I just don't hear this fuel pump like I did my other fuel pump. I think this is your problem. Go back to what @ndfrigi said in post #5 and then look at this article: http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php The ECU for the FI is what turns the stock pump on. With that gone, you have to do the simple mod to get your fuel pump relay to kick on. |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:33 AM |
