Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
surfdogskier |
Oct 22 2019, 04:53 PM
Ok, I connected the 4 pin to the ground as mentioned per the sirandy info and now when I turn the key, I hear the pump. Now I have gas but trying to crank her, I have flames in one or both the carbs. A little scary. She won't start but I'm not pushing her. Only got my 10 year old daughter turning the key as I play with the throttle.
Are the jets not spraying is my only idea? |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:42 PM |
