Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
bbrock |
Oct 22 2019, 05:58 PM
Did you set the float levels on both carbs when you installed them? First thought is that maybe the float valves aren't shutting off fuel when the bowls are full. Beyond that, I'll leave it to those who actually know something about carbs.
Lo-Fi Version | Time is now: 22nd May 2024 - 10:07 AM |
