Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
rhodyguy |
Oct 23 2019, 07:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The Dansk from pelican is the quivelent of a 009? Is there a notch on the top edge of the distributor body at what should be cyl #1?
surfdogskier |
Oct 23 2019, 07:49 AM
The Dansk from pelican is the quivelent of a 009? Is there a notch on the top edge of the distributor body at what should be cyl #1? I'm not seeing a notch. That is probably my problem. My plug wires may not be firing in correct order. I wired like my last distributor had them but this one may be different. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:54 PM |
