Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
sixnotfour |
Oct 23 2019, 09:48 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE I have the pull the plug off the no. 4 pin. go by the picture Attached image(s) |
GregAmy |
Oct 23 2019, 10:02 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
QUOTE I have the pull the plug off the no. 4 pin. go by the picture With key on and pump running, pull the fuel pump relay. Pump should stop running. With key on and pump running, pull the power supply relay. Pump should stop running. Do both tests with key off. Report results. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:53 PM |
