Hate me, I converted to carbs. Question about priming |
surfdogskier |
Oct 22 2019, 02:14 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell.
Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
Gatornapper |
Oct 23 2019, 10:12 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
#1 - you need this jumper on your relay board (lower left):
(IMG:http://www.914world.com/bbs2/uploads_offsite/i890.photobucket.com-21449-1571847147.1.jpg) #2. - you need to get a fuel pressure regulator and gauge and set the pressure to 3psi max. My dual Weber 44's run fine with the above. GN I finally had my fill of FI and ripped out the entire fuel injection in 30 minutes. I was finally able to clean my engine out nice Installed dual weber carbs. I'm going to hold on to my fuel injection if I ever change my mind or sell. Question. I installed a new low pressure fuel pump so my lines are empty. When I turn the key, I can't hear it like my FI fuel pump. What is the best way to prime these when they are new? Everything is hooked up except for the throttle cable. Should I disconnect the fuel lines to get the air out of lines. I do not know if these are vacuumed or not is why I am asking. |
surfdogskier |
Oct 23 2019, 06:11 PM
[quote name='Gatornapper' post='2756688' date='Oct 23 2019, 12:12 PM']
#1 - you need this jumper on your relay board (lower left): (IMG:http://www.914world.com/bbs2/uploads_offsite/i890.photobucket.com-21449-1571847147.1.jpg) #2. - you need to get a fuel pressure regulator and gauge and set the pressure to 3psi max. My dual Weber 44's run fine with the above. GN This didn't work in my case. Pump still stayed on. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:00 PM |
