V8 Project Update, Phase 4 - Maintenance |
FL000 |
Oct 22 2019, 08:38 PM
Member Group: Members Posts: 389 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Hi World, I am moving on to the next phase of my project, and have enough things planned that I will call it phase 2. Hopefully this thread will motivate me to see it through quicker, and maybe help someone else at the same time.
Phase 1 was my 7 year adventure taking a banged up 73 roller and installing a SBC, renegade kit, and Sheridan body kit. Here is basically what it looks like now Had fun driving it for a summer and a winter, then realized I am ready to start the next round of upgrades. The list in no particular order and consists of: Heat and a/c Audi 01E install Fuel injection Boxster brakes Fix passenger door gap Time and money varies, so no timeline for when it will get done, but my wife's 62 Lincoln is next in line so I do have some encouragement to finish! |
76-914 |
Nov 15 2020, 10:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Damn. So many possibilities. Where is the origin of the oil leak? So many fouled plugs, too! Have you done a leak down test yet? Sounds like a head gasket leak between the water & oil passages but not between the cylinders. The odd thing is fouled plugs on both sides. 0 chance of blowing head gasket on both sides or cracked heads on both sides unless it overheated but you'd have noticed that. Looking forward to seeing what you find when you tear it down. (IMG:style_emoticons/default/beerchug.gif)
FL000 |
Nov 15 2020, 05:38 PM
Damn. So many possibilities. Where is the origin of the oil leak? So many fouled plugs, too! Have you done a leak down test yet? Sounds like a head gasket leak between the water & oil passages but not between the cylinders. The odd thing is fouled plugs on both sides. 0 chance of blowing head gasket on both sides or cracked heads on both sides unless it overheated but you'd have noticed that. Looking forward to seeing what you find when you tear it down. (IMG:style_emoticons/default/beerchug.gif) No leak down test yet but may once I get the engine and trans removed. I did a compression test before WCR and all were in the 150 psi area. Guessing that isn’t the case now (IMG:style_emoticons/default/lol-2.gif) Here is the oil and coolant; kind of hard to tell which is which right?! The coolant was a nice green last I checked. |
76-914 |
Nov 16 2020, 10:39 PM
Damn. So many possibilities. Where is the origin of the oil leak? So many fouled plugs, too! Have you done a leak down test yet? Sounds like a head gasket leak between the water & oil passages but not between the cylinders. The odd thing is fouled plugs on both sides. 0 chance of blowing head gasket on both sides or cracked heads on both sides unless it overheated but you'd have noticed that. Looking forward to seeing what you find when you tear it down. (IMG:style_emoticons/default/beerchug.gif) No leak down test yet but may once I get the engine and trans removed. I did a compression test before WCR and all were in the 150 psi area. Guessing that isn’t the case now (IMG:style_emoticons/default/lol-2.gif) Here is the oil and coolant; kind of hard to tell which is which right?! The coolant was a nice green last I checked. The top pic is from the radiator and the lower from the oil pan? |
FL000 |
Jan 8 2021, 08:05 PM
Damn. So many possibilities. Where is the origin of the oil leak? So many fouled plugs, too! Have you done a leak down test yet? Sounds like a head gasket leak between the water & oil passages but not between the cylinders. The odd thing is fouled plugs on both sides. 0 chance of blowing head gasket on both sides or cracked heads on both sides unless it overheated but you'd have noticed that. Looking forward to seeing what you find when you tear it down. (IMG:style_emoticons/default/beerchug.gif) No leak down test yet but may once I get the engine and trans removed. I did a compression test before WCR and all were in the 150 psi area. Guessing that isn’t the case now (IMG:style_emoticons/default/lol-2.gif) Here is the oil and coolant; kind of hard to tell which is which right?! The coolant was a nice green last I checked. The top pic is from the radiator and the lower from the oil pan? That’s funny, actually the top pic is from oil pan and bottom is the coolant. It was a mess. |
Lo-Fi Version | Time is now: 29th April 2024 - 10:26 AM |
