simple coil question, 1974 914 1.8 |
brcacti |
Oct 23 2019, 02:28 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, does the coil come out with taking one bolt in the back sort of unseen? Wanted to clean the terminals up file and sand.
SteveL |
Oct 23 2019, 03:03 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Yep. Just took mine out an hour ago.
10mm wrench. Use the box end, you can feel the bolt head but cannot see it. Loosen it up a few turns, then the omega shape bracket will be loose enough for the coil to slide out. |
brcacti |
Oct 23 2019, 05:03 PM
Thanks Steve, just took it out and cleaned up the terminals where ever I could. Can anyone tell me what effect this might have? To be more clear if you had bad connections to the coil what are some of the problems you might have?
jim_hoyland |
Oct 23 2019, 08:06 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
If you have it out and don’t know how old it is, it might be time to replace.
Tdskip |
Oct 23 2019, 09:30 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Bosch blue coil still the recommendation?
porschetub |
Oct 23 2019, 11:15 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
jim_hoyland |
Oct 24 2019, 05:19 AM
Lo-Fi Version | Time is now: 4th June 2024 - 10:04 AM |
