6 alternator wiring |
rgalla9146 |
Oct 25 2019, 01:18 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Attached are pics of the rear of my alternator and the original 6 alternator harness
connections. How to connect/adapt ? The white plastic plug is obvious as is the large red Batt+ The small red has nowhere to go....no small Df stud. Currently available alternators require modification of the harness but no further info is provided. Can my combination work ? My charge lamp bulb is known good. TIA Attached thumbnail(s) |
Jonathan Livesay |
Oct 25 2019, 02:00 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
The 2 spade terminals look to be D- and DF, see the raised letters near them? So that leaves the small red wire to be D+ I think. Are there threads inside the hole next to the D+ ?
Jonathan Livesay |
Oct 25 2019, 02:54 PM
Upon further examination itt's a threaded stud which comes through from the inside.
rgalla9146 |
Oct 25 2019, 04:22 PM
Upon further examination itt's a threaded stud which comes through from the inside. Jonathan Yes, that is where the stud would be if it was so equipped. I've looked inside that cover and there is no feature to attach a stud or elec. lead to. The alternator must be a later version but I can't believe it simply can not be adapted. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:24 AM |
