LSD recommendations, LSD reccomendations |
Charles Freeborn |
Nov 5 2019, 05:08 PM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Greetings.
While my engine is out for top end refresh I'm also planning on installing a limited slip diff. What have people run and why? Obvious choices are Guard (true LSD) Quaif, Wavetrac (Torque bias). Pros / cons of those types? I've heard the TB is easier on the rest of the gearbox. Not too concerned about having to run LSD additive as the fluids get regular service anyway (every event). Quick rundown of the car: 100% track use (not street legal) Little to no AX - all road course. 2.0L 4 cyl with fairly extensive mods. Estimated hp around 150. 901 side shift with AFKSX gearsets. Car weighs approx 1700 lbs (18 & change with me in it) Currently running Toyo RR 225/50 slicks. May step up to Hoosiers if I get more serious about racing. I've got another set of wheels for running in the wet with R888R's. Not great rain tires, but that's what's on those wheels now. When they're done I'll probably switch to RA1's. Thanks! |
yeahmag |
Nov 12 2019, 12:12 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
The Wavetrac is unique in the TB LSD world. Check the "How It's Different" tab:
http://www.wavetrac.net/technical.htm I'm currently shopping for one for my car... |
jd74914 |
Nov 12 2019, 06:06 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
The Wavetrac is unique in the TB LSD world. Check the "How It's Different" tab: http://www.wavetrac.net/technical.htm I'm currently shopping for one for my car... It is a pretty neat piece-they basically added a Salisbury action to a TB so you remove requirement for wheel loading without needing clutches. How much do they run? |
Lo-Fi Version | Time is now: 19th May 2024 - 12:03 PM |
