Center Console Clock Rubber Seal |
63acornwall |
Nov 7 2019, 08:50 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
I now have a working VDO clock for the center console but am missing the rubber seal to mount it with .
Hole in console is 80mm diameter , clock is 60 mm diameter . Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search ! |
dr914@autoatlanta.com |
Nov 7 2019, 09:35 AM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Factory vdo console gauges are 60 and use a rubber sleeve to fit which we now make. Aftermarket vdo are 50 and use a spacer ring to fit into the factory console hole
I now have a working VDO clock for the center console but am missing the rubber seal to mount it with . Hole in console is 80mm diameter , clock is 60 mm diameter . Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search ! |
Lo-Fi Version | Time is now: 25th April 2024 - 08:53 PM |
