FS Replated parts -Steering U joints, P rod tubes, rear hubs, Rear shock bolts, Tow hook, Spare tire hold down |
bdstone914 |
Nov 7 2019, 01:04 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
3 pair Rear shock bolts $40 a set
Rear Hubs $75 a set 1 set left Steering U joints $40 a set Push-rod rod tubes $40 a set w/o O rings, $60 with Viton o rings Tow hook $50 Sold but have more - Spare tire hold down plate and bolt $25 Shipping by USPS flat rate small $8, Medium duty $16. Attached thumbnail(s) |
DRPHIL914 |
Nov 8 2019, 08:12 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
bruce I will take a set of U-joints and a set of the rear shock bolts!
Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! |
bdstone914 |
Nov 8 2019, 10:12 AM
@DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364']
bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce |
Lo-Fi Version | Time is now: 19th April 2024 - 06:00 PM |
