914bub |
Member ![]() ![]() Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None ![]() |
I was wondering why nobody has produced a stainless heat exchanger "kit" for 914's? I don't mean stainless heat exchangers like the ones that pop up now and then that were made in the past. I mean a kit that would use a separate upper and lower plate that would be held together with "cheese head" screws like the other heater system tin for 914's. Since it seems like a lot of the stock non-stainless metal ones are rusting away it would make it so anybody could cut off their old metal, bolt-on the new stainless halves and be set for life. I'm sure the pipes occasionally rust away but I've seen very few that had messed up exhaust pipes. Seems like it's usually the outers that are wasting away.
I'm also curious who made the stainless ones, how long ago and for how long? I'm sure the initial cost of tooling wouldn't be cheap but it seems like with all the messed-up ones floating around somebody could sell tons of them. They'd be a lot cheaper to ship than a complete heat exchanger as well. @Mikey914 ? Maybe? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Actually, yes we have been on this for some time. The tooling is a little spendy, I'd look for these to be available end of January. I prefer to have the poo arts in the final stage before we open up the GB.
Yes, and if all goes as plamned these will be quite reasonable. But this wasn't the big announcement. (IMG:style_emoticons/default/biggrin.gif) But it is of that caliber. |
914bub |
Actually, yes we have been on this for some time. The tooling is a little spendy, I'd look for these to be available end of January. I prefer to have the poo arts in the final stage before we open up the GB. Yes, and if all goes as plamned these will be quite reasonable. But this wasn't the big announcement. (IMG:style_emoticons/default/biggrin.gif) But it is of that caliber. Cool! I didn't know you were working on those. Anybody have a history on the complete stainless heat exchangers? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Well you can get brand new four cylinder stainless steel heat exchangers. The price isn't 914 cheap but pretty reasonable for a product that fits and functions as designed by Porsche and should last another 50 years. Plus there are always used ones available for cheap.
Mikey914 |
The idea is that we can make a retrofit, that if yours are good, would be a simple procedure to replace. It also puts us one step closer to making a complete unit. You know me. If I can make it we can drive the costs down. Everyone wins. (IMG:style_emoticons/default/biggrin.gif)
914bub |
The idea is that we can make a retrofit, that if yours are good, would be a simple procedure to replace. It also puts us one step closer to making a complete unit. You know me. If I can make it we can drive the costs down. Everyone wins. (IMG:style_emoticons/default/biggrin.gif) I'm super looking forward to them! I didn't know you could still buy new ones but I bet they're super spendy. |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
I would be first in line for these. I drive all year and have rusted out 2 or 3 sets of shells. My defroster really struggles to keep up with the freezing rain when the HE's are leaking.
I'm a little wary of the SS HE's and their ability to seal well against the copper crush gasket in the heads. They seem thin compared to the wider surface of the stock casting. In my little world a perfect HE would be the stock mild steel tubing, wrapped in SS shells for durability. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,598 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
If Mark can't do them I can.. It sounds like he is already in it so I will stay out of this pool for now.. We are actually looking at making completely new heat exchangers/headers for the 4cyl guys.. We have the 6 cylinder version nailed..
TargaToy |
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 713 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region ![]() ![]() |
Mikey914 |
Thanks Ben,
Did get your PM and we will be stocking his exhaust also. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
at one time the clamshells were made in japan and by someone in northern europe. However what happened is that every one was leery about putting clamshells around the pipes that could have holes in them by now and pass exhaust gasses into the cockpit, killing people. Hence because of sue happy, everyone discontinued them
I was wondering why nobody has produced a stainless heat exchanger "kit" for 914's? I don't mean stainless heat exchangers like the ones that pop up now and then that were made in the past. I mean a kit that would use a separate upper and lower plate that would be held together with "cheese head" screws like the other heater system tin for 914's. Since it seems like a lot of the stock non-stainless metal ones are rusting away it would make it so anybody could cut off their old metal, bolt-on the new stainless halves and be set for life. I'm sure the pipes occasionally rust away but I've seen very few that had messed up exhaust pipes. Seems like it's usually the outers that are wasting away. I'm also curious who made the stainless ones, how long ago and for how long? I'm sure the initial cost of tooling wouldn't be cheap but it seems like with all the messed-up ones floating around somebody could sell tons of them. They'd be a lot cheaper to ship than a complete heat exchanger as well. @Mikey914 ? Maybe? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
at one time the clamshells were made in japan and by someone in northern europe. However what happened is that every one was leery about putting clamshells around the pipes that could have holes in them by now and pass exhaust gasses into the cockpit, killing people. Hence because of sue happy, everyone discontinued them (IMG:style_emoticons/default/agree.gif) I can see liability being an issue, any product like that better come with some extra large fine-print to ensure the manufacturer and/or reseller isn't sued out of existence if someone was to put them on rusted out pipes and subsequently dies from the carbon monoxide in the cabin. (IMG:style_emoticons/default/unsure.gif) |
mb911 |
at one time the clamshells were made in japan and by someone in northern europe. However what happened is that every one was leery about putting clamshells around the pipes that could have holes in them by now and pass exhaust gasses into the cockpit, killing people. Hence because of sue happy, everyone discontinued them (IMG:style_emoticons/default/agree.gif) I can see liability being an issue, any product like that better come with some extra large fine-print to ensure the manufacturer and/or reseller isn't sued out of existence if someone was to put them on rusted out pipes and subsequently dies from the carbon monoxide in the cabin. (IMG:style_emoticons/default/unsure.gif) That's a great point.. |
Mikey914 |
SSF was making them before they go bought my Adan’s (I think) .
Anyhow, yes liability is an issue. But that is one of the reasons we do testing, and sometimes you see the 3rd or 4th generation of product by the time the GB is even announced. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,906 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
SSI, they are for sale online through multiple sources $1500-$1800..did they get the 2.0 tooling when JP dansk bought em ???
https://www.newparts.com/product/ssi-heat-e...BCABEgLoB_D_BwE |
Mikey914 |
I think so.
Good news is we can made for much less and there are some improvements to be made. |
Lo-Fi Version | Time is now: 5th July 2025 - 03:04 PM |
