Is this LSD ?, ... or perhaps some other phenomenae ? |
drifter914 |
Nov 8 2019, 10:03 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
So I have this '76 914-8 with an LS-1 conversion & one day while pulling out of a graveled area I kicked it a bit & noticed leaving 2 ruts behind instead of the one I was used to in a previous 914.
So the other day when I had it up on jack stands I started it up, put it in 1st gear & let it idle while I got out to look... left rear wheel was turning fwd at a constant rate, while the right was also turning fwd, but at a slower rate. Could it be that I have some sort of limited slip arrangement here ? Transaxle is a modified 901 & has the numbers HA 22095 on the bottom of the case. Thanks for any info on this... Terry |
rhodyguy |
Aug 10 2020, 12:08 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Then everything starts melting and Stairway to Heaven seems like it's been playing for an hour. Then your girl friend turns into a lizard. Then you pull over and turn the car off. Having sex with a lizard was not part of the game plan.
KELTY360 |
Aug 10 2020, 01:20 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Then everything starts melting and Stairway to Heaven seems like it's been playing for an hour. Then your girl friend turns into a lizard. Then you pull over and turn the car off. Having sex with a lizard was not part of the game plan. .....ask him how he knows. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 09:55 AM |
