Is this LSD ?, ... or perhaps some other phenomenae ? |
drifter914 |
Nov 8 2019, 10:03 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
So I have this '76 914-8 with an LS-1 conversion & one day while pulling out of a graveled area I kicked it a bit & noticed leaving 2 ruts behind instead of the one I was used to in a previous 914.
So the other day when I had it up on jack stands I started it up, put it in 1st gear & let it idle while I got out to look... left rear wheel was turning fwd at a constant rate, while the right was also turning fwd, but at a slower rate. Could it be that I have some sort of limited slip arrangement here ? Transaxle is a modified 901 & has the numbers HA 22095 on the bottom of the case. Thanks for any info on this... Terry |
settador |
Nov 9 2019, 11:19 AM
Newbie Group: Members Posts: 31 Joined: 16-May 05 From: Lee, NH Member No.: 4,086 Region Association: None |
Last time I had LSD
I saw colors and the road was like sea |
Lo-Fi Version | Time is now: 26th April 2024 - 04:33 AM |
