'73 914 2.0....what to do first?, New to a project like this...where to start? |
AKFish |
Nov 11 2019, 05:39 PM
Newbie Group: Members Posts: 29 Joined: 10-December 18 From: Nampa, Idaho Member No.: 22,714 Region Association: Rocky Mountains |
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project...
About this time last year, I purchased a 1973 914 2.0. The previous owners bought it as part of a bundle of 914's and only kept a couple. I have some documentation from when the car was first purchased, but the more recent owners have proven elusive. It was owned by a member here named "kurbfrog" but he/she has not responded to my contact attempts, so recent history is a bit murky. Sounds like the guy I really want to talk to, headed south of the border in a bit of a hurry. I acquired the car in a partially disassembled state. The engine, a 2.0 with it's original FI still attached, is out and pretty much everything is removed from the engine bay and the interior. Many of the removed parts are carefully bagged up and some even have labels. On the whole, the car is in pretty solid condition, however, there are some of the typical rust issues..... The engine shelf has been cut for A/C and there is rust in the hell hole and I can see rust developing in the outer long (I think that's what it is called). My reading here would suggest that there is a lot more than meets the eye. What I would really like to do is find out if the engine runs...and if so, just put the car back together and drive it for a while. I could decide after that, if a "rustoration" is right for me...I have zero background in fabrication/welding. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? P.S. My car came with this 1975 Roller that is pretty well gutted. |
jcd914 |
Nov 12 2019, 12:29 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You can run the engine outside the car.
It is easiest if you use an engine compartment relay panel and plug the engine harness and FI harness into the panel. There are a few wires that normally come from the vehicle harness that will need to be hooked up to the relay panel to provide power. You will also need to wire the starter and fuel pump as well as provide a fuel source for the pump and a place for the fuel return to go. It takes some figuring out but is not too bad. I set mine up with jack stands under the engine crossbar and the tail of the transmission. I also used a spare relay panel I had around and mounted it to a simple stand. Fuel supply and return were just a 2 gallon fuel jug with fuel hoses stuffed in it. I did move the fuel jug several feet away from the engine to keep fumes away. Jim |
Lo-Fi Version | Time is now: 5th May 2024 - 08:43 AM |
