'73 914 2.0....what to do first?, New to a project like this...where to start? |
AKFish |
Nov 11 2019, 05:39 PM
Newbie Group: Members Posts: 29 Joined: 10-December 18 From: Nampa, Idaho Member No.: 22,714 Region Association: Rocky Mountains |
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project...
About this time last year, I purchased a 1973 914 2.0. The previous owners bought it as part of a bundle of 914's and only kept a couple. I have some documentation from when the car was first purchased, but the more recent owners have proven elusive. It was owned by a member here named "kurbfrog" but he/she has not responded to my contact attempts, so recent history is a bit murky. Sounds like the guy I really want to talk to, headed south of the border in a bit of a hurry. I acquired the car in a partially disassembled state. The engine, a 2.0 with it's original FI still attached, is out and pretty much everything is removed from the engine bay and the interior. Many of the removed parts are carefully bagged up and some even have labels. On the whole, the car is in pretty solid condition, however, there are some of the typical rust issues..... The engine shelf has been cut for A/C and there is rust in the hell hole and I can see rust developing in the outer long (I think that's what it is called). My reading here would suggest that there is a lot more than meets the eye. What I would really like to do is find out if the engine runs...and if so, just put the car back together and drive it for a while. I could decide after that, if a "rustoration" is right for me...I have zero background in fabrication/welding. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? P.S. My car came with this 1975 Roller that is pretty well gutted. |
barefoot |
Nov 11 2019, 07:47 PM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project.. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? First see if the engine will turn over. you can use a screwdriver thru the access hole by the flywheel to slowly turn the flywheel, if it turns, then set up a battery and do a compression test, or better yet buy a cheap leakdown tester and check leakdown rates. If that passes, you can run the engine just setting on wood blocking by jurry rigging fuel supply (easier with carbs) |
AKFish |
Nov 11 2019, 08:14 PM
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project.. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? First see if the engine will turn over. you can use a screwdriver thru the access hole by the flywheel to slowly turn the flywheel, if it turns, then set up a battery and do a compression test, or better yet buy a cheap leakdown tester and check leakdown rates. If that passes, you can run the engine just setting on wood blocking by jurry rigging fuel supply (easier with carbs) I removed spark plugs and turned the engine over by hand, replaced plugs and I can still turn over but with the resistance of compression. No audible scraping or crunching...oil appears to be new. Can the D-Jet FI be run with the engine out? Thanks very much. |
Superhawk996 |
Nov 12 2019, 12:36 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Lo-Fi Version | Time is now: 5th May 2024 - 02:33 PM |
