My 914 is not OSHA compliant, Interior engine noise |
Superhawk996 |
Nov 14 2019, 08:48 AM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If it's too loud, you're too old . . . as the saying goes. (IMG:style_emoticons/default/lol-2.gif)
VaccaRabite |
Nov 14 2019, 10:59 AM
En Garde! Group: Admin Posts: 13,440 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I dunno about too loud too old.
I do know I'm only 44 and have lost a good bit of my hearing. I'd like to try and keep whats left. My cabin got a LOT quieter after I replaced my GT lid with a stock engine lid and rain tray, and also installed the 914rubber engine side sound pad. You can have a conversation in the car now without shouting. Unfortunately it means I also hear all the other squeaks and rattles in the cabin that I never was able to hear before. Zach |
Superhawk996 |
Nov 14 2019, 01:42 PM
I dunno about too loud too old. I do know I'm only 44 and have lost a good bit of my hearing. I'd like to try and keep whats left. My cabin got a LOT quieter after I replaced my GT lid with a stock engine lid and rain tray, and also installed the 914rubber engine side sound pad. You can have a conversation in the car now without shouting. Unfortunately it means I also hear all the other squeaks and rattles in the cabin that I never was able to hear before. Zach What? I can't hear you! Seriously I'm in the same boat w.r.t. hearing loss. Too many years around jet engines, guns, race cars, inside manufacturing plants, loud stereo's, etc. However, I think we get lost in trying to compare these cars to modern cars. They will never be as quiet nor should they be. The sound of the car and an air cooled engine is part of what the experience is about. IMHO if you want to have a quiet conversation, get a modern 911 or an even quieter a Buick! |
Superhawk996 |
Nov 14 2019, 01:55 PM
On a more serious note if you want sound attenuation here is what can be done:
Switch from Leather / Vinyl seats to cloth. You want the accoustic absorption of the cloth. Switch to thicker carpet pile. Put shoddy under your floor carpets if you don't want thicker pile. Put foam or shoddy on ther underside of the dash (on the bare sheetmetal) Air leakage = sound leakage Seal any stray holes in the dash and/or rear bulkhead Make sure your window seals and Targa seals are in good shape and sealing Put shoddy behind the rear back pad & make sure you have the engine side sound deadner in place too. Put some sort of headliner (soft, fuzzy, acoustic material) on the underside of the targa. You could also inset the door panels with cloth / Alcantera materials. Question is - how much are you willing to do? Even if you did all the suggestions above, it still will never be as quiet as a Lexus for a multitude of reasons. |
Betty |
Nov 15 2019, 08:00 AM
Driver Group: Members Posts: 511 Joined: 10-December 04 From: Hurst, TX Member No.: 3,255 Region Association: South East States |
My biggest noise problem is the passenger screaming: " slow down in the corners!". BWAHAHAHAHAHAhahahahahahahaha.......... You too? (IMG:style_emoticons/default/av-943.gif) |
sixnotfour |
Nov 15 2019, 09:59 AM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Brand new build..needs a redo? What?
$20 https://www.earplugstore.com/boxes-of-dispo...m-earplugs.html $400 https://www.bose.com/en_us/products/headpho...s_700_soapstone Attached image(s) |
porschetub |
Nov 15 2019, 03:55 PM
I went from individual K&N filters back to stock plastic air cleaner,noticed a reduction in noise and the advantage of better filtration and ease of tuning the carbs.
I did spend some time fixing the backfire damage on one side of the aircleaner due to blocked pump nozzles and one broken (leaking) air bleed screw. I'am still running the stock firewall insulation and have added some sound deadening behind the backpad...not too bad until you hit 3K + rpm then it gets a little loud. |
Rikyrat |
Dec 11 2019, 12:34 PM
Member Group: Members Posts: 58 Joined: 30-January 19 From: Phoenix Member No.: 22,844 Region Association: None |
Thought I would ring in on this. I am in the midst of cleaning the engine bay, have sandblasted and repainted.
I installed FatMat brand sound insulation, on the firewall, pretty simple. Then I covered the engine side of the sound mat, with another layer of it. As an aside, when I scrubbed the sound mat, I was surprised to find that it was green, every 914 I have had, this is my third, the mat appeared to be black, probably do to it being filthy. When I went to put the insulation on the sound mat, I could not get it to adhere, so I used contact cement on it. Then screwed the mat to the firewall, which I was hesitant to do, but the original pins did not want to hold it in place. Hopefully this will tone down some of the engine noise, but who cares, if you really don't want to hear it or want to listen to music, wear ear buds. Also, when I get around to doing the interior, this summer, I am going to do the same thing to the cabin side of the firewall, in addition to doing the floor, before installing new carpet. Have a nice day |
Lo-Fi Version | Time is now: 7th May 2024 - 02:23 PM |
