Subie conversion 2005 XT Turbo 2.5L question |
9144me2enjoy |
Nov 15 2019, 11:20 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Without getting into a lot of depth on this subject just wondering if anyone sees a problem with a Subie conversion using a 2005 Subaru Outback XT Turbo 2.5L H4 engine combined with a 901 Transmission. (250hp/359 lbs). Vs other Subie conversion. Also isn’t it usually better to buy a donor car instead of piecing it together (engine/ECM/electronics etc)?
JRust |
Nov 16 2019, 11:27 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Without getting into a lot of depth on this subject just wondering if anyone sees a problem with a Subie conversion using a 2005 Subaru Outback XT Turbo 2.5L H4 engine combined with a 901 Transmission. (250hp/359 lbs). Vs other Subie conversion. Also isn’t it usually better to buy a donor car instead of piecing it together (engine/ECM/electronics etc)? Don't use the 901. You'll spend just as much for the adapter plate setup as you will making the suby work. You will be much happier in the long run with the suby trans. It does require more work in the long run but is so worth it. You need custom gauges but realistically you'd be doing most of them anyway. If I was doing it over again. I would just do the suby ez30 instead. You can get more power out of a turbo setup but there is more to mess with. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:10 AM |
