| Tdskip |
Nov 16 2019, 01:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Hi guys - I know how it is commonly done including Ian’s great video. Is there a reason why not to use bushing grease instead of softsoap?
So you want the bushing NOT to move or rotate ones installed? I assume that is a reason but wanted to ask. Thanks. |
Tdskip Why not use bushing grease on a-arm bushings? Nov 16 2019, 01:01 PM
Chi-town petroleum based greases will degrade rubber Nov 16 2019, 01:30 PM
914werke An alternate to soap would be Glycerin Nov 16 2019, 01:56 PM
Tdskip Hi guys - happy Saturday.
What about standard sil... Nov 16 2019, 02:47 PM
IronHillRestorations KY works great on factory rubber bushings Nov 17 2019, 06:33 AM
bbrock The press fit of the original rubber bushings is s... Nov 17 2019, 09:37 AM
Tdskip
The press fit of the original rubber bushings is ... Nov 17 2019, 10:43 AM
jmitro
So you want the bushing NOT to move or rotate one... Nov 17 2019, 11:03 AM
Superhawk996
So you want the bushing NOT to move or rotate on... Nov 17 2019, 11:44 AM
Tdskip Great discussion, thanks Nov 17 2019, 11:59 AM
Chi-town Or just use a quality poly bushing like Powerflex ... Nov 17 2019, 03:33 PM
Superhawk996
Or just use a quality poly bushing like Powerflex... Nov 17 2019, 04:04 PM
Tdskip Well - tried the URO bushings and they kept deform... Nov 17 2019, 04:17 PM
Superhawk996
Well - tried the URO bushings and they kept defor... Nov 17 2019, 05:02 PM
bbrock
Well - tried the URO bushings and they kept defor... Nov 17 2019, 06:11 PM
Tdskip @Superhawk996 - thanks for the detailed response.... Nov 17 2019, 05:22 PM
Chi-town When a rubber bushing binds it acts as just like t... Nov 17 2019, 09:23 PM
jmitro It also doesn't bind like the rubber stock un... Nov 17 2019, 11:32 PM
Mikey914 The OEM are intended to set a zero preload on the ... Nov 17 2019, 09:45 PM
Chi-town If you get a Powerflex bushing to bind you have do... Nov 18 2019, 12:39 AM
Mikey914
If you get a Powerflex bushing to bind you have d... Nov 18 2019, 10:54 AM
914bub They are torsilastic bushings.
... Nov 18 2019, 01:00 AM
Tdskip As a sidenote to this discussion on the British ca... Nov 18 2019, 06:55 AM
IronHillRestorations The factory front bushings are relatively cheap, ... Nov 18 2019, 07:18 AM
Chi-town If you set up the bushings according to the angles... Nov 18 2019, 03:04 PM
Mikey914 We are making the rears now and will be ready in a... Nov 18 2019, 03:56 PM
Chi-town
We are making the rears now and will be ready in ... Nov 18 2019, 04:00 PM
Mikey914
We are making the rears now and will be ready in... Nov 18 2019, 09:11 PM
Superhawk996 There is a obviously a heated debate of poly vs. r... Nov 18 2019, 07:25 PM
Chi-town Modern rubber bushing design is completely differe... Nov 18 2019, 10:56 PM
Mikey914 EPDM that was used on the OEM parts has stood up f... Nov 19 2019, 12:40 AM
Superhawk996
The ultimate design would be to go to a roller b... Nov 19 2019, 05:21 AM
Chi-town I completely agree with @Superhawk996 on this on... Nov 19 2019, 10:11 AM
Mikey914
We are trying to restore our 75 bumpers and notic... Nov 19 2019, 10:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
