How to remove block connectors |
dt4 |
Nov 17 2019, 07:49 AM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Is there a way of pulling the wires from the headlight block connectors without damaging the connector
I want to pull the wiring loom back to the bulkhead Attached thumbnail(s) |
Mark Henry |
Nov 17 2019, 08:03 AM
They have little spring clip prong that pops up when you install them in the plastic connector. If you slide a little flat jewelers screwdriver down the between the connector and the plastic you can push the prong down and pull the clip out.
When reinstalling the connector you will have to bend the prong back up. |
JeffBowlsby |
Nov 17 2019, 08:04 AM
914 Wiring Harnesses Group: Members Posts: 8,503 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Mark Henry |
Nov 17 2019, 08:10 AM
dt4 |
Nov 17 2019, 10:38 AM
Brilliant
Thank you |
Lo-Fi Version | Time is now: 14th May 2024 - 02:41 AM |
