Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
FlacaProductions |
Nov 17 2019, 08:09 PM
Senior Member Group: Members Posts: 1,594 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
My fuel pump ground runs up through the fuel tank access hole and grounds at the bolt that anchors the windshield washer reservoir.
Lo-Fi Version | Time is now: 24th May 2024 - 06:27 AM |
