Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
dr914@autoatlanta.com |
Nov 18 2019, 03:52 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
should have run the hot and the ground together in a cable and connected to the fuel pump wiring harness pigtail in the right front of the engine compartment
Lo-Fi Version | Time is now: 18th May 2024 - 11:35 AM |
