Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
trojanhorsepower |
Nov 18 2019, 05:52 PM
OK Guys,
Thanks for the input. Please note that I bought this car in boxes... There is a hood release in the engine bay? SirAndy, so now I am confused. Which wire is the correct one, or should I run both? I have always read that I need to run the striped wire to the fuel pump and ground it locally, but you guys are making me second guess that. When I look at the schematic it looks like the striped wire goes to the regulator plate (whatever that is) and the brown wire goes straight to the chassis ground. So, how would the relay switch to ground? I know this may sound dumb, but I don't know.... |
SirAndy |
Nov 18 2019, 06:45 PM
Resident German Group: Admin Posts: 41,655 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
OK Guys, Thanks for the input. Please note that I bought this car in boxes... There is a hood release in the engine bay? SirAndy, so now I am confused. Which wire is the correct one, or should I run both? I have always read that I need to run the striped wire to the fuel pump and ground it locally, but you guys are making me second guess that. When I look at the schematic it looks like the striped wire goes to the regulator plate (whatever that is) and the brown wire goes straight to the chassis ground. So, how would the relay switch to ground? I know this may sound dumb, but I don't know.... Now that you mention it, i'm pretty sure the FI brain grounds the fuel pump relay, not the fuel pump ground. Sorry for the confusion ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 24th May 2024 - 12:56 PM |
