Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
jcd914 |
Nov 18 2019, 07:26 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Fuel pump wires go through the engine shelf below the battery tray and there is normally a grommet, probably old and hard and cracking. I think 914rubber has replacement grommets.
And yes the FI controls the relay so you only need to extend the power wire for the pump and ground it locally. The factory used a larger gauge wire to the fuel pump when they moved it up front. The longer the electrical run the more resistance there is and so you need a heavier wire to carry the current for longer distance. Jim |
Lo-Fi Version | Time is now: 18th May 2024 - 11:52 AM |
