Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
JeffBowlsby |
Nov 18 2019, 07:46 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
To relocate the FP to the front, follow the factory schematic for the 75-76 cars:
Use 12GA power wire from the 14 pin connector on the relay board (preferably black/red) Use 12GA ground wire to chassis ground at the FP (Brown only) |
Lo-Fi Version | Time is now: 18th May 2024 - 09:08 AM |
