CV Joint, 12-pt bit size for bolts? |
dcecc1968 |
Nov 19 2019, 08:52 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Can't seem to find a reference for the size of this bit. Thanks for your help.
-Don |
Rob-O |
Nov 20 2019, 12:32 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Or start by hand and get 3-4 turns in before going to the wrench. Yes most folks aren't really good at safety wire, but it will keep the bolt from backing out. You also do not need to do every bolt you can do every other. Assuming the safety wiring is done correctly. I’d say it’s 50% of the pictures I see if a safety wire job where the wire is done incorrectly, which would allow the bolt to loosen even with the safety wire. |
Lo-Fi Version | Time is now: 7th May 2024 - 02:42 PM |
