CV Joint, 12-pt bit size for bolts? |
dcecc1968 |
Nov 19 2019, 08:52 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Can't seem to find a reference for the size of this bit. Thanks for your help.
-Don |
Valy |
Nov 21 2019, 01:23 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Allen bolts are a mistake.
Use the original bolts, new washer and make sure the surface of the bolts, CV and drive flange are clean and DRY of any oil or grease. Also make sure there is no RTV there as some like to use it there. The reason those bolts back up is that dirt and grease captured on above mentioned surfaces create temporary pressure that makes you think the bolt is fully torqued. Then the dirt gives up and the bolt torque goes out the window and even the washer doesn't help anymore. |
Lo-Fi Version | Time is now: 7th May 2024 - 12:30 PM |
