Green Bilstein question, optional green Bilstein's for 2.0 |
drifter914 |
Nov 20 2019, 01:46 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi all.. I am trying to verify that the pair of green Bilstein front struts I have were indeed offered as optional equipment for the 914 (probably the '73-'74 2.0 models).
If anyone has a 914 with this option, please respond. Also, it would be very helpful to see a pic of it on the 914 ( pull a front wheel ? ), showing the 914 part number. TIA... Terry |
sixnotfour |
Nov 20 2019, 02:07 PM
914 Wizard Group: Members Posts: 10,429 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
here some info;
http://www.914world.com/bbs2/index.php?showtopic=335082 based on that info if factory installed installed bils will have the PN stamped in the tube... replacements have a sticker... |
drifter914 |
Nov 21 2019, 10:59 AM
Does any other World member have the green Bilstein front struts ?
Or am I the lone ranger? (IMG:style_emoticons/default/confused24.gif) |
914Sixer |
Nov 21 2019, 11:16 AM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a set it the warehouse. Running 914-6 brakes.
Nov 21 2019, 11:19 AM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think you guys are talking about two different things. Bills for 4 & 6 are different.
ctc911ctc |
Nov 21 2019, 12:02 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I have a '74 2.0 barn find that was put away in '84 with 22K miles It has green shocks/struts CTC911CTC Hi all.. I am trying to verify that the pair of green Bilstein front struts I have were indeed offered as optional equipment for the 914 (probably the '73-'74 2.0 models). If anyone has a 914 with this option, please respond. Also, it would be very helpful to see a pic of it on the 914 ( pull a front wheel ? ), showing the 914 part number. TIA... Terry |
914werke |
Nov 21 2019, 12:12 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Does any other World member have the green Bilstein front struts (HOUSINGS) ? Or am I the lone ranger? (IMG:style_emoticons/default/confused24.gif) I do. Was on the LE when I restored the car. I replace them with Boges with Bils inserts.Still have um in a box. Intended to replaced rebuild but I think the inserts/parts were the stumbling block. Its been a while. I think the inserts are still available but with only 911 valving |
sixnotfour |
Nov 21 2019, 12:26 PM
I think you guys are talking about two different things. Bills for 4 & 6 are different. in my post your right.. (IMG:style_emoticons/default/headbang.gif) here is a pic of the number -4 Attached image(s) |
JeffBowlsby |
Nov 21 2019, 03:19 PM
914 Wiring Harnesses Group: Members Posts: 8,495 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have a couple sets of the front 914 Bils struts available FS.
drifter914 |
Nov 21 2019, 03:58 PM
According to 914 Tech Tips 700 by G. Hussey: 1st edition I think :
237. (page 44) ALL 914 front strut inserts will interchange with the '69-'84 911 insert types. 367 (page 66 ) The best 914 to buy, besides a 6-cylinder, is a '73-'74 914 2.0 with the BILSTEIN suspension package & front and rear anti-sway bars. My main problem with identification of the ones I have comes from a previous owner marking out the numbers on the Bilstein USA sticker on both struts. I believe this may have been the 914 #. |
sixnotfour |
Nov 21 2019, 04:16 PM
So you want new inserts for your 914 Bil. Struts ??
914werke |
Nov 21 2019, 05:48 PM
Were these ON a car? Throw a front disc on the spindle if it fits you know its the /4 ver.
Lo-Fi Version | Time is now: 11th May 2024 - 11:23 AM |
