Dellorto DRLA 40's / SOLD, SOLD |
drifter914 |
Nov 22 2019, 05:45 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Very nice set of dual Dells for sale. Dellorto DRLA 40's in VG condition. Will need to be cleaned & rekitted for best result. Comes with:
30mm venturis 60 idle 175 air jet 118 main jets 9164 emulsion tubes Also included: Empi intake manifolds, Hex bar linkage Facet fuel pump throttle cable bracket (bolts to engine case). extra venturis ( 34 & 36mm ). spare jets, gaskets and : The Dellorto Superperformance Tech Book by Bob Tomlinson Plus: German air flow meter for synchronizing carbs Does not include velocity stacks & odd bits of hardware for final install. $600. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) 0. shipped in 2boxes to lower 48 (IMG:style_emoticons/default/bye1.gif) |
drifter914 |
Nov 26 2019, 09:21 AM
Tuesday bump. This is basically everything you will need to do a quality carb conversion on your 914-4. Dell 40's can be jetted up or down & venturis changed to match your 1.7 / 1.8 or 2.0 Type 4 engine, including larger bore & strokers.
Camshaft changes may also be necessary to match your build. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:01 PM |
