Another "S" bites the dust |
wndsrfr |
Nov 25 2019, 01:51 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Exiting the bus stop at Daytona firmly in 4th gear put the power to it and POP...
Here's the carnage... Attached thumbnail(s) |
Krieger |
Nov 25 2019, 07:18 PM
Advanced Member Group: Members Posts: 4,693 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/wacko.gif) wow! Looks like your pinion shaft was taking some abuse too. Is that a bullet intermediate plate?
Krieger |
Nov 25 2019, 07:20 PM
How much time did you get on this trans? Do you run an lsd?
wndsrfr |
Nov 25 2019, 09:14 PM
How much time did you get on this trans? Do you run an lsd? The "S" gearset came from a 912 trans that was a core that came with the car when I got it 6 years ago, so can't say if it was abused by PO's or not. Yep, it's a billet intermediate plate and there is an LSD in this trans. Lots of hours on the trans but about 550 race miles, say maybe 7-8 hours on the "S" gearset since it was installed last summer. Charlie at Intersport came up with another "S" gearset from his stash so will be back in action soon. I'll be using my shorter geared MSX box for next race at Roebling in Savannah in 3 weeks... |
Charles Freeborn |
Nov 25 2019, 11:39 PM
Member Group: Members Posts: 244 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Hmmm. Same gear set as mine. What engine / hp are you pushing through it?
Krieger |
Nov 25 2019, 11:53 PM
That's not a lot of run time. I would think that having an S gear would make it easier on the trans. What kind of hp are you putting out? I have a 3.0 with that puts out just under 250 hp and stock gearing on my 901. No lsd. I have 24 track days on it with no problems
wndsrfr |
Nov 26 2019, 07:03 AM
Hmmm. Same gear set as mine. What engine / hp are you pushing through it? It's a 2.7 215hp on a Mustang dyno.... That gearbox is set up with AFNSZ, use it at longer tracks Watkins Glen, VIR, Road Atlanta. The other box is AFMSX for shorter tracks, Roebling, Summit Point. Daytona was too fast even with taller tires, 225/50/16's I was at 7600rpm every lap from turn 4 to past the tri oval s/f line, about 150mph... |
Krieger |
Nov 26 2019, 10:22 AM
I have one mod that a racer engine builder John William's at Otto's in Venice beach told me I must have. He said the rear studs that hold the tail cone work loose under load. The higher power is loosening the nuts/studs that hold the tail cone. He had me install longer studs (the ones that hold the tail cone on). Make them so they protrude through the forward end of the trans case. Put nuts on the studs as they are coming through. Tighten the nuts. Then weld those nuts to the studs. I have recently added an oil cooler.
wndsrfr |
Nov 26 2019, 03:39 PM
I have one mod that a racer engine builder John William's at Otto's in Venice beach told me I must have. He said the rear studs that hold the tail cone work loose under load. The higher power is loosening the nuts/studs that hold the tail cone. He had me install longer studs (the ones that hold the tail cone on). Make them so they protrude through the forward end of the trans case. Put nuts on the studs as they are coming through. Tighten the nuts. Then weld those nuts to the studs. I have recently added an oil cooler. Now that's great advice on strengthening the studs...cooler may be in the works later if I'm running more than sprint sessions.... |
Lo-Fi Version | Time is now: 19th April 2024 - 08:49 AM |
