FS - Powder coated fan shroud $125, Hot tanked, media blasted, and powder coated silver |
Superhawk996 |
Nov 29 2019, 04:35 PM
914 Guru Group: Members Posts: 5,748 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Along the path of obtaining a needed set of cooling flaps for GA004310, I ended up with an extra fan shroud that came along for the ride with the cooling flaps. I needed the cooling flaps so they are not included with this shroud.
As I was prepping parts for my other two 2.0L engine builds, I had this shroud hot tanked to clean out all the residual oil, it was media blasted, and finally powder coated silver. $125 shipped |
Superhawk996 |
Dec 9 2019, 05:59 AM
Bump
GregAmy |
Dec 9 2019, 09:50 AM
Advanced Member Group: Members Posts: 2,267 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Not in the market for a shroud, but curious what the flapper system is worth? I jsut removed a fully-functional system from my car, including fucntioning bellows, to install Chris Foley's oil cooler kit.
Superhawk996 |
Dec 9 2019, 07:56 PM
Not in the market for a shroud, but curious what the flapper system is worth? I jsut removed a fully-functional system from my car, including fucntioning bellows, to install Chris Foley's oil cooler kit. My engine GA004310 came without flaps or a thermostat - Damn PO's! Likely explains why the heads off that engine were cracked! I paid $90 for a complete, functional used OEM Tstat with braket & pulley. I've seen the flaps alone pop up on this site from time to time but they seem to be sporadic. Last set I saw was about $30 + shipping IIRC. The problem would be shipping as they can be a bit fragile if not packed well but doable if someone takes the time to do it right. |
Superhawk996 |
Dec 19 2019, 09:27 AM
Bump
Superhawk996 |
Jan 18 2020, 12:48 PM
bump
Superhawk996 |
Feb 2 2020, 08:13 AM
$125 shipped CONUS
Knock $40 off for shipping if anyone can do local pickup |
Lo-Fi Version | Time is now: 25th April 2024 - 11:51 AM |
