Engine wiring harness query |
914Greg |
Dec 1 2019, 05:06 PM
Newbie Group: Members Posts: 14 Joined: 17-November 19 From: Australia Member No.: 23,647 Region Association: None |
I have bought a roller without an engine wiring harness, it was a 4 that will be converted to a 6 with MSD and built in alt regulator, would it be just as easy to start from scratch with a harness than mod an old one?
IronHillRestorations |
Dec 2 2019, 12:25 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The OP says "will be converted to 6"
Mark Henry |
Dec 2 2019, 02:29 PM
The OP says "will be converted to 6" Sorry thought it said "was". You will have to decide on several things - to keep the relay board or delete it. -where you plan to mount the MSD box. -where you're mounting the fuel pump. -what extra gauges you will run and how you want to run the wiring. My engine harness I deleted the relay board and made it a quick conect to the main harness using the proper connector, but I still have a couple connections on the right side where I mounted my regulator and MSD. My MSD I did a stealth install in the stock location by modifying a /6 CDI mount. Then I still have a secondary harness for some of my gauges, again with a quick disconnect. Using quick disconnect(s) my harnesses stay on the engine for easy R&R of the engine. Taking the extra time sorting and planning of where everything goes will make for a much cleaner cable harness install. If you're not that great with wiring and for the proper connectors Perry is you're best bet for getting a clean harness that is custom built to your needs. |
Lo-Fi Version | Time is now: 20th April 2024 - 01:48 AM |
