Optimum Type 4 for road racing |
Charles Freeborn |
Dec 1 2019, 06:52 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Title says it - taking opinions on a competitive T4 used for vintage group road racing. Primary tracks will be PIR (Portland), The Ridge and ORP. PIR is a relatively flat high speed 12 turn track. The other 2 are much more technical - slower, more turns, shorter straights.
Cases need to be EA or EB to qualify for the run group I'm shooting for (F). Currently have a 94/71 with big valve heads, 9.5:1, IDF 44's Webcam 86B. It's sound, but getting tired - showing some cracking in the heads, so if I get another season from it I'll be happy. Prefer to keep CR in the range that can run on pump gas - also durability is a factor. Some thoughts/questions: Shorter stroke / bigger bore for better top end? - with current gearing I'm running out of redline on longer straights. Billet crank from SCAT? Split Port heads from SCAT? Mahle Euro pistons or CP or JE. Nickasil cylinders worth the expense? Very interested in hearing the specs on any of your builds - how they behaved and how long-lived they were. Gearbox is a separate issue- will get to that when I've got the engine specs sorted. Many thanks. |
GregAmy |
Dec 2 2019, 07:42 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
What are the regs? I find it interesting that you have to run a specific case ID, yet the really important regs seem to be Way Wide Open.
And of course...what's your budget? I run mine in historics, where regs don't exist* and declared displacement is solely by the honor system (among thieves). So power is ultimately limited exclusively by the wallet. GA *Regs that are unenforced or unenforceable are not regs. |
Charles Freeborn |
Dec 2 2019, 09:28 AM
What are the regs? I find it interesting that you have to run a specific case ID, yet the really important regs seem to be Way Wide Open. And of course...what's your budget? I run mine in historics, where regs don't exist* and declared displacement is solely by the honor system (among thieves). So power is ultimately limited exclusively by the wallet. GA *Regs that are unenforced or unenforceable are not regs. I want it to have the appearance of a 1.7 and keep it at 2.0L +-. Less than $10k Sanctioning bodies are ICSCC (FIP class), SOVREN (small bore group) and to a lesser degree SVRA (maybe 1 event per year). |
GregAmy |
Dec 2 2019, 10:33 AM
I want it to have the appearance of a 1.7 and keep it at 2.0L +-. See? (IMG:style_emoticons/default/happy11.gif) Sounds like you need to rebuild what you have. And send us a photo of the car so we can protest you. (IMG:style_emoticons/default/av-943.gif) |
Charles Freeborn |
Dec 2 2019, 05:58 PM
I want it to have the appearance of a 1.7 and keep it at 2.0L +-. See? (IMG:style_emoticons/default/happy11.gif) Sounds like you need to rebuild what you have. And send us a photo of the car so we can protest you. (IMG:style_emoticons/default/av-943.gif) Pretty commonplace 'round here... I'll post a pic of your car just to keep the whiners off the scent.. (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:50 AM |
