OK guys - how to build a “civilized” 3.2 914/6 |
Tdskip |
Dec 2 2019, 01:21 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Assuming the goal is a daily driver civilized build that you’d get out of after 500 without feeling beat up and frazzled - how do you do that?
The 3.2 I have had a complete Motrinic and I am assuming that keeping that would be step one in that build , yes? Is the rest down to muffler choice and sound deadening etc.? |
Rob-O |
Dec 2 2019, 02:31 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I think George has good points. When I think civilized I think noise and drivability. I’d also stick with heat exchangers to help noose and give you heat. I’d put a quiet muffler on it. Hard to do 500 mikes with muffler drone AND a big motor right behind your head. I’d consider putting the engine bay sound deadening in, as well as the rubber mats installed behind the back pad.
Different gearing in the trans, maybe. Or a trans swap. Something that gives you low rpm’s in 5th gear at highway speeds. Again, spinning at 3000 at 75mph wears on you after an hour or two. Hopefully these guys that take their 914’s long distance will chime in. Ask #clayperrine, he and Betty drive their cars all across the country. You’ll get some expert advice from those folks. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:57 AM |
