WTT: 911 Front Hub, Need a matching set |
bigkensteele |
Dec 3 2019, 08:12 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
mepstein |
Dec 3 2019, 09:15 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ken - I'm pretty sure I have a mismatched set. I don't think I will be home until friday so I'll check then.
bigkensteele |
Dec 3 2019, 09:19 PM
P_G |
Dec 5 2019, 11:28 AM
Newbie Group: Members Posts: 1 Joined: 6-January 18 From: Burbank Member No.: 21,759 Region Association: Southern California |
Hello
I have a pair of early Hubs in excellent condition. Thank you Paul |
mepstein |
Dec 7 2019, 08:30 AM
@bigkensteele
Ken - here’s the two hubs. Early hub is in great condition. Later hub must have gotten dropped on the edge. Will need the bumps filed so the rotor sits flat on the face of the hub. 5 minutes with a flat file should do it. No studs on either hub. Let me know which one you want and we’ll do the trade. Thanks, mark Attached thumbnail(s) |
bigkensteele |
Dec 7 2019, 10:37 AM
@mepstein Hi Mark, if you feel the later one can be easily fixed, I will go with that one. My early is not as clean as yours but it is in excellent shape. If you don't mind, I will press out my studs.
I will respond to your PM with my address and #. Thanks! Ken |
mepstein |
Dec 7 2019, 11:00 AM
@mepstein Hi Mark, if you feel the later one can be easily fixed, I will go with that one. My early is not as clean as yours but it is in excellent shape. If you don't mind, I will press out my studs. I will respond to your PM with my address and #. Thanks! Ken All sounds good and yes, I’m sure it will clean up fine with a few strokes of a file but if for any reason you are not satisfied we will work something out so that you are. |
Lo-Fi Version | Time is now: 26th April 2024 - 01:37 PM |
