Door stay kit |
Door stay kit |
mepstein |
Dec 7 2019, 09:58 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Help me understand. The door stay kit I’m using comes with a pin but it’s too big for the hole. I could make the hole bigger but there’s still no groove for a clip. Stock pin on right
? @Mikey914 Attached thumbnail(s) |
Mikey914 |
Jan 15 2020, 11:00 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Our current game plan is to go back to stock hole size. The parts will be just like OEM. Then you can buy a slightly oversized pin or a stock sized pin. The stock woill fit nicely into the stock arm. If you have a problem with the mount being oversized and clicking. You can use the oversize pin and drill the arm to match, But until we run out we will have the oversized arms. 2 different kits.
914lover17 |
Sep 7 2021, 09:34 PM
Newbie Group: Members Posts: 45 Joined: 11-June 21 From: Kitchener-Waterloo Member No.: 25,622 Region Association: Canada |
Our current game plan is to go back to stock hole size. The parts will be just like OEM. Then you can buy a slightly oversized pin or a stock sized pin. The stock woill fit nicely into the stock arm. If you have a problem with the mount being oversized and clicking. You can use the oversize pin and drill the arm to match, But until we run out we will have the oversized arms. 2 different kits. What size pins are in the current kit? https://914rubber.com/door-stay-rebuild-kit-for-porsche-2021 |
Lo-Fi Version | Time is now: 17th May 2024 - 06:16 PM |
