FS Engine jack tool and leftover parts, Tangerine R. engine lift tool for floor jack $100 |
marksteinhilber |
Dec 9 2019, 04:20 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
(SOLD) Fiberglass front air dam. Not stock or LE valence. Has been reinforced at tabs and there are some other FG repairs on backside, ready to prep and paint. accepts rubber lower skirt from 914 rubber, but none included. $70
(SOLD) Tangerine Racing jack tool for changing engines. Has round dowel plug that drops into standard floor jack. Does not fit Harbor Freight Pittsburg and other brands that has screw in fitting. $100 plus shipping (SOLD) rear reflector - PORSCHE between taillights for 914. Trunk lock must be removed, but trunk can be opened using small push rod through small hole in reflector, or by setting up a remote cable release. $60 for reflector, unfortunately I couldn't find the 12V release solenoid. (SOLD) targa sail bottom narrow chrome moldings, Left side is brand new from Sierra Madre, in package, with 4 clips. Right side is used but good condition, no clips. Old ones from your car can be reused. new were about $30 each. $35 for the pair. sail rear trim hold down bracket. one only for L or R. shown in photo with targa side trim mouldings $8 (SOLD) 1975-76 914 door cards, Right and Left. no significant rips visible, but masonite board has some warp due to moisture, useable, restorable. most hardware for handles and pockets have been removed and not included $20 each Local pickup suggested. (SOLD) 914 US tail light assembly ® with lens & bulbs, good working condition, no melts or cracks in housing. decent rear seal. needs new lens seal. Lens is driver quality with crazing, some faint stress cracks, and is missing one of the three threaded holders. Crazing and cracks don't leak water. no hex nuts or washers for housing. $40 matching (L) tail light lens also driver quality, with some crazing. $10 Passenger foam footrest $25 (SOLD)Drivers plywood footboard with throttle stop $15 Working AM FM Sapphire radio complete with faceplate and knobs. Correct for 74 faceplate weave. I have video of it playing available. Mono $250 possible show car resto??? Shifter plastic bushing, dirty but new $4 Gearbox side shift console with fork and bronze slider bushings. Bronze bushings need to be brazed together to stay in place or the bronze bushing needs a groove machined to add a circlip. roll pin in ball fitting has slop that needs attention. I fixed another of these by drilling and tapping for a set screw at 90 degrees to roll pin. $40 (SOLD) Steel repair parts. L and R footwell corners inside front wheel wells. You harvest what you need instead of fabricating part that is not made. Has jacking donuts too! $20 each. I can cut these down to what you want for shipping if desired. (SOLD) Wiper sheet metal valence pieces. Not perfect, but easier to fix these parts than to fab new parts from scratch. Or use for repair pieces to repair curved channels. $10 per side. Driver side inner and outer suspension console. From dry Cali car. very little rust in hell hole area. I can harvest what you need from this piece so you can install. $150 harvested. $80 as is but is bulky to ship. [attachmentid=722 252][attachmentid =722257] Attached image(s) |
Thunderchief |
Dec 9 2019, 06:15 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
I already have the rear reflector but if you can find the release solenoid then I'd be interested in that.
marksteinhilber |
Dec 11 2019, 10:40 AM
I already have the rear reflector but if you can find the release solenoid then I'd be interested in that. Sorry, I looked for the solenoid and it appears I let it go with the 1974 car I sold a year ago. I've got some edits to do to the classified ad now. Thanks for the interest. Mark |
Lo-Fi Version | Time is now: 4th May 2024 - 06:09 PM |
