Headlight gremlins |
john77 |
Dec 10 2019, 06:26 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
My headlights have decided to randomly turn themselves on and off as I drive, which is a lot of fun at night on the I405 as drivers think some obnoxious d*ck is flashing them.
I cleaned up the grounds and all the ground wire connectors by both headlights but it’s still happening. Could this be relay connected, or are they more a once dead completely dead kind of deal? I thought i’d ask before I drop $20 on a new one. For the record, I have those sealed GE led headlights, and it’s happening simultaneously to both, so I know it’s not the bulbs. |
SirAndy |
Dec 10 2019, 08:03 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Could this be relay connected, or are they more a once dead completely dead kind of deal? No and neither. There's no relay for the headlight power, the relays next to the headlights are for the motors that move them up/down. (IMG:style_emoticons/default/shades.gif) |
john77 |
Dec 10 2019, 08:08 PM
Could this be relay connected, or are they more a once dead completely dead kind of deal? No and neither. There's no relay for the headlight power, the relays next to the headlights are for the motors that move them up/down. (IMG:style_emoticons/default/shades.gif) I know the relays next the the headlights are for the motors. I meant the how/low beam relay under the dash. If it was faulty couldn’t it still stop the power to the headlights? |
Costa05 |
Dec 10 2019, 09:18 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Could this be relay connected, or are they more a once dead completely dead kind of deal? No and neither. There's no relay for the headlight power, the relays next to the headlights are for the motors that move them up/down. (IMG:style_emoticons/default/shades.gif) I know the relays next the the headlights are for the motors. I meant the how/low beam relay under the dash. If it was faulty couldn’t it still stop the power to the headlights? Coincidentally I was just looking at the wiring diagram for the high/low beam relay under dash on my 73. Yes that relay is fed off the dash switch. Its a two position relay. The "at rest" position feeds low beams. When the relay is activated it jumps over to the high beam side. Both sides of the relay then run through your fuse panel. Fuses 1 through 4. Then goes to headlights. Lt Rt low beams....Lt Rt high beams positive wires. The relay is cheap if you want to replace it. Can be bench tested but replicating could be tough. Worth cleaning all five spade connectors first and take it for another drive. Mine were pretty corroded. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:36 PM |
