Headlight gremlins |
john77 |
Dec 10 2019, 06:26 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
My headlights have decided to randomly turn themselves on and off as I drive, which is a lot of fun at night on the I405 as drivers think some obnoxious d*ck is flashing them.
I cleaned up the grounds and all the ground wire connectors by both headlights but it’s still happening. Could this be relay connected, or are they more a once dead completely dead kind of deal? I thought i’d ask before I drop $20 on a new one. For the record, I have those sealed GE led headlights, and it’s happening simultaneously to both, so I know it’s not the bulbs. |
AZBanks |
Dec 11 2019, 12:08 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Hijacking the thread since my issue is light related.
My light were working perfectly until about 4 nights ago. The drivers side headlight does not go up when I turn on the lights. The light bulb is on but I have to turn the knob on the back of the motor to manually raise the light up into position. I will check the relay. Is there any other typical cause of this kind of issue I should check? |
Mikey914 |
Dec 11 2019, 04:53 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hijacking the thread since my issue is light related. My light were working perfectly until about 4 nights ago. The drivers side headlight does not go up when I turn on the lights. The light bulb is on but I have to turn the knob on the back of the motor to manually raise the light up into position. I will check the relay. Is there any other typical cause of this kind of issue I should check? I'd bet relay try to wiggle it around may just be a bad contact in the socket. But typically that would be a relay. Anyone want to put me down for $5 on the switch for this thread (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 12:59 PM |
