Airflow/Horsepower limit for stock 2.0L intake system? |
greggearhead |
Dec 12 2019, 11:32 AM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
OK, I did search, and couldn't really find anything.
My basic question - when does the 914 2.0L intake become a restriction to power? I have a built VW 412 - 2056 cc Type 4 * 9550 RAT cam * LE-180 heads (914 2L combustion chamber, 42mm intake, 36mm exhaust) * Mallory Unilite vacuum advance distributor, Mallory Promaster coil, Mallory Hyfire CDI * Stock 412 heater boxes & Thunderbird exhaust * 2L Bus plenum and throttle body * 2L 914 runners * Ford "Design II" F1TE-D9A (Bosch 0280150947) 24# injectors (modified) * SDS programmable EFI * Oil bath air cleaner housing modified to use large circular filter element I have a pair of IDF manifolds, and some VFR throttle bodies. Roughly equivalent to Weber 40IDFs (maybe a bit better in terms of flow). Engine made 115hp at the wheels. I'm just wondering if the (improved) stock intake is a cork or not? (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1576171976.1.jpg) |
GregAmy |
Dec 13 2019, 01:08 PM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I think we're done here.
But while I have everyone else's attention...will the 2L 914 TB fit easily on the bus plenum? You may recall - if you read my friggin post! - that I'm developing a system to fit on my 2L 914 per SCCA Limited Prep regs, which requires use of the stock unmodified throttle body. Everything else is free. So if the 914 2L runners are good, maybe I can adapt that to a better plenum and run from there. I suppose I could look into modifying anything, or fabricating from scratch. Would much prefer an "easy button". As a related aside, my 914 does have a decklid over the engine, so no clearance concerns. Thanks! |
Mark Henry |
Dec 13 2019, 01:47 PM
I think we're done here. But while I have everyone else's attention...will the 2L 914 TB fit easily on the bus plenum? You may recall - if you read my friggin post! - that I'm developing a system to fit on my 2L 914 per SCCA Limited Prep regs, which requires use of the stock unmodified throttle body. Everything else is free. So if the 914 2L runners are good, maybe I can adapt that to a better plenum and run from there. I suppose I could look into modifying anything, or fabricating from scratch. Would much prefer an "easy button". As a related aside, my 914 does have a decklid over the engine, so no clearance concerns. Thanks! http://www.sdsefi.com/air12.html |
ChrisFoley |
Dec 14 2019, 11:13 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I suppose I could look into modifying anything, or fabricating from scratch. Would much prefer an "easy button". I thought the HP rules were for a 1.8L engine, in which case the 2L TB isn't the one you need to use. If you are allowed to use the Bus plenum and 2L runners (requires 2L intake bolt pattern on the heads) I'm sure the 1.8L TB can be fitted to it and altered to include TPS. |
GregAmy |
Dec 15 2019, 10:20 AM
I thought the HP rules were for a 1.8L engine, in which case the 2L TB isn't the one you need to use. If you are allowed to use the Bus plenum and 2L runners (requires 2L intake bolt pattern on the heads) I'm sure the 1.8L TB can be fitted to it and altered to include TPS. January Fastrack just came out; they rejected my request to run the 2L engine in H Production Limited Prep, stating it has "too much displacement". I'm not taking the 1.8L engine into HProd on Limited Prep regs; I just don't think it has a chance there, starting with 76hp versus the 2019 champ's 91hp OHC 3-valve, and the 914 has to weigh 200 pounds more on top of that. Juice ain't worth the squeeze. I think the killer car in HP now is the 2015 Honda Fit, which start with 130 crank HP and only has to weigh 150# more than the 1.8L 914. And we're going to America's Dyno, Road America, for this years' Runoffs. I want to develop something for my 2L street car that could be adapted to the 2L race car, ifn' they ever changed their mind about allowing the 2L into HP using Limited Prep regs; to do that requires the 2L TB. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:13 PM |
