Airflow/Horsepower limit for stock 2.0L intake system? |
greggearhead |
Dec 12 2019, 11:32 AM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
OK, I did search, and couldn't really find anything.
My basic question - when does the 914 2.0L intake become a restriction to power? I have a built VW 412 - 2056 cc Type 4 * 9550 RAT cam * LE-180 heads (914 2L combustion chamber, 42mm intake, 36mm exhaust) * Mallory Unilite vacuum advance distributor, Mallory Promaster coil, Mallory Hyfire CDI * Stock 412 heater boxes & Thunderbird exhaust * 2L Bus plenum and throttle body * 2L 914 runners * Ford "Design II" F1TE-D9A (Bosch 0280150947) 24# injectors (modified) * SDS programmable EFI * Oil bath air cleaner housing modified to use large circular filter element I have a pair of IDF manifolds, and some VFR throttle bodies. Roughly equivalent to Weber 40IDFs (maybe a bit better in terms of flow). Engine made 115hp at the wheels. I'm just wondering if the (improved) stock intake is a cork or not? (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1576171976.1.jpg) |
Dave_Darling |
Dec 13 2020, 12:56 AM
The general consensus seems to be that the exhaust will limit you before the intake does. Switching over to a good tuned exhaust (like the Tangerine Racing one) will give you a very significant bump in power.
--DD |
Lo-Fi Version | Time is now: 17th May 2024 - 06:52 PM |
