FS: Billet Tuna Can - NEW!, * Featured Item * |
914werke |
Dec 14 2019, 07:38 PM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Here is a solution for oil starvation when driving your 914/4 in the manner it was designed!!
Highly recommended for ANY 914, street or tracked. Simple install. Available HERE & in the members vendor section (IMG:style_emoticons/default/bye1.gif) |
914werke |
Apr 2 2020, 10:39 PM
Its a common concern but in reality the sump once installed is no lower than the engine mount bar. If you are dragging the sump on anything, there is something else going on ~
Its purpose it to MAINTAIN oil pressure. The 914 was designed to be capable of navigating curvy roads at high rates of speed and (with the right tires) + G-force's. The result of which is to cause the oil in the bottom of the engine to slosh away from the pickup. By extending the PU into a small oil reservoir at the lowest point of the engine, that should never occur. |
Lo-Fi Version | Time is now: 25th April 2024 - 07:44 AM |
