fan belt problems |
fan belt problems |
jat914 |
Dec 15 2019, 02:20 PM
Newbie Group: Members Posts: 24 Joined: 3-December 13 From: Arizona Member No.: 16,718 Region Association: None |
I had to replace the fan belt on my race built 2065 motor. The replacement belt is made in China and at high rpms it kept flying off! Has anyone had this problem and is there a solution?
rgalla9146 |
Dec 15 2019, 07:13 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It is less likely a counry of origin issue and more likely a hardware problem.
There is a recent thread here concerning belt / alignment / brackets |
porschetub |
Dec 17 2019, 02:19 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It is less likely a counry of origin issue and more likely a hardware problem. There is a recent thread here concerning belt / alignment / brackets I only use Contitech belts because they are very durable and fit well same as I only use OEM oil filters but that's just me. Make sure your altenator pulley isn't worn and polished up (slippage) ,make sure you check the mounting brackets (as mentioned) ,try to do a basic alignment before tensioning the belt. |
Lo-Fi Version | Time is now: 26th May 2024 - 05:56 PM |
