6 speed trans and 993 engine, Inverted 6 speed trans from a 993 |
Miguel K R |
Dec 15 2019, 04:47 PM
Newbie Group: Members Posts: 20 Joined: 12-December 19 From: Portugal (Europe) Member No.: 23,732 Region Association: None |
Hi,
I am going to fit a 6 speed G50 trans (inverted) from a 993, with a 3.6L varioram engine. I will have to use a cable shifter (from Patrick Motorsports or CableShift. California Motorsports modifies the trans for a cableshift running from the side but that is excluded for me as I am based in Europe and would have to send the trans to the US to be modified, and back to Europe). My question is if there is enough length for the long nose of the trans . I know I have to cut the trunk for the inverted trans. I have seen at the Renn... forum a car which had the bellhousing and shaft shortened at Patrick Motorsports in 2005 but they did not explain if that was necessary, or if as an alternative, the opposite side could have been shortened. CMS states that shortening the bellhousing is not recommended for G50's later than '89 due to starter compatibility issues. I guess the issue is the elimination of the guide bushing for the starter when the bellhousing is shortened, and that is not an issue for '89 and earlier cars, because High Torque Starters which do not use that bushing are available. For '90 and later cars I have not been able to find those starters. Can someone help with information on the application of the 6 speed trans from a 993 ? I am building a 914-6 GT replica and already started applying the fender flares, and modifying the engine cover with a second grille. |
mepstein |
Dec 15 2019, 06:34 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don’t know the exact length but the G50 trans at our shop look a lot longer than a 915 trans, not to mention they are pretty heavy. You will need two separate mufflers, one for each side of the trans. Not a big issue but won’t look like a GT. The varioram also is too tall for the 914 engine bay. The induction won’t fit under the engine grill. The combo of engine, trans and associated parts will add a lot of weight over the stock 914-6.
Might want to rethink some of your choices before you buy the parts. You can probably get the starter you need from a Porsche dealer or online parts store. I would post this in the garage instead of the paddock. @SirAndy (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:51 PM |
