Is there a "how to.." for crank measurement, and bearing verification? |
malcolm2 |
Dec 16 2019, 11:07 PM
Advanced Member Group: Members Posts: 2,739 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I am gonna make a 2 liter from my 1.8. So I have a refreshed 71mm crank that I have been told has been ground to -0.010.
I measured as best as I can with a digital mic and got about 59.66 on the mains and 49.65 on the rod journals. Where can I find the STD specs and ranges ? were they 60 and 50, respectively? Since I know nothing about this crank, how can I verify the 71 mm measurement? |
Mark Henry |
Dec 17 2019, 09:24 AM
I only use STD cranks or standard (under) cranks I get turned down to .010, reason is I won't use a crank that ever had a burnt journal.
Cheap magnaflux, hold a crank by the nose, give it a solid rap with a hammer and it should ring. If it's just a thud it's cracked. This doesn't replace magnaflux, but I've never had a crank fail that passed the ring test. |
Lo-Fi Version | Time is now: 29th April 2024 - 05:28 PM |
