| downrange |
Dec 21 2019, 03:21 PM
Newbie ![]() Group: Members Posts: 22 Joined: 1-January 18 From: Pennsylvania Member No.: 21,747 Region Association: MidAtlantic Region |
Wipers stop in mid sweep. Any way to set starting point or is the motor shot?
| Mark Henry |
Dec 21 2019, 03:27 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
It's the linkage, you have to R&R, take apart clean and lube.
| rgalla9146 |
Dec 22 2019, 07:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,930 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
The short arm on the motor has to be repositioned.
Remove the wiper arms before doing anything. Now for the bad news. Unless you have rubber arms this is a gas tank out and air box out job |
| downrange |
Dec 22 2019, 03:35 PM
I was afraid of that. The current park position is pretty much straight up. From the straight up position the wiper sweeps 90 degrees toward the driver side, then 180 degrees to the passage side. When the switch is turned off the wipers park at straight up.
You mentioned that the short arm can be adjusted. According to the attached diagram there does not appear to be an adjustment unless you are referring to the connection at the motor. Can I remove the motor and reposition the connection to adjust the short arm? Thanks for any help you can provide. ![]() |
| rgalla9146 |
Dec 22 2019, 04:12 PM
Yes, the motor always parks in the same spot.
Loosen (don't remove) the 10mm nut on that short motor arm, pry arm loose (it's easy) use a wiper arm to rotate the wiper shafts to the side you want the wipers to park on. Your choice. REMOVE THE WIPER ARM Tighten the nut on the short arm. Test operate the wipers before re-attaching the arms. Park on the wrong side ? Rotate the short arm 180 degrees. Forget to remove arms ? visit body shop for estimate. Maybe windshield shop too. |
| downrange |
Dec 22 2019, 05:05 PM
Thanks. I appreciate your help.
Lo-Fi Version | Time is now: 13th February 2026 - 07:29 PM |
