What's your volt meter reading when cruising around town? |
raynekat |
Jan 9 2020, 11:58 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
Pursang |
Jan 10 2020, 02:12 AM
Member Group: Members Posts: 232 Joined: 19-January 13 From: Beaverton Member No.: 15,386 Region Association: Pacific Northwest |
When driving I think it runs around 13v or so. Warm engine idle is in the 10-11 range but turn signal or brake lights drop it even more. Headlights on is a huge drain. If you know of a shop in the Portland area (SW) that is proficient with the 914 electrical maladies, please let me know. Thanks.
Lo-Fi Version | Time is now: 21st May 2024 - 11:18 AM |
